Tony Parker
Advice needed re cable pulling winch
Loving that
 Capstan winches are so underrated, used to have one on the front of a Series 2a Landrover, brilliant tool.
Totally agree, first used one for scrub clearance 20 years ago, was a Zollern Muli and we had it mounted on an 044, superb bit of kit but ridiculously expensive, I believe they’re about 6k now and that’s before you put a power head on! Was much heavier than the Eder but would pull a lot more
Share this post
Link to post
Anyone  actually using a  pulley as force multiplier and if so what pulley?
FC booklet says sheave should be minimum X18 diameter size of cable.  Most pulleys are alot smaller diameter
So for this winch you would  need a pulley to be over 200mm size take a 10-12mm rope and rated 3t or above.
Does such a pully block exist?
Which booklet is that?
I use one of these for redirects
WWW.FRJONESANDSON.CO.UK
Single Pulley for 13mm RopePulleys in our Heavy-duty Prussik range have tamper-proof Rivets, in compliance with CE EN12278 (2007) & NFPA (1983)*These Pulleys are available in Aluminium or Stainless Steel, with Bushings or Roller Bearings...
Share this post
Link to post
Hi I have a trifor and it’s ace a bit of a faf but moved some massive monkey puzzle butts still green and bloody heavy ,I got mine second hand for £25 so if you could get one cheap like I did no worries and if you don’t get on with it I am sure you could sell it on no problem.
Cheers Mark
Share this post
Link to post
My friend showed me a little homelite XL chainsaw winch he's had for years. Looks a we'll make thing! Will pull 1 t straight pull or 2 with a pulley. Going to borrow it soon for a job and most likely twist his arm and buy it from him after!
Look such a handy small package to have for all sorts of applications.
Share this post
Link to post
Like a lewis winch.
LEWISWINCH.COM
The Lewis Winch high-powered portable chainsaw winch, Portable Winch and Lewis Winch Multi Drill, Snatch Block, check out all our Winch Products.
Share this post
Link to post
I’ve used a Lewis winch, very good but limited by drum capacity whereas capstan you’re only limited by length of cable/roe you have available. Not seen the multi drill attachment before looks useful
Share this post
Link to post
Quote
Quote
Compatibility of equipment is essential. Winch
components, e.g. shackles and blocks of equal
rating, vary in size depending on the material
used in their construction. Compatibility of
equipment includes selecting blocks that are
appropriate for the diameter of wire rope in
use, with respect to the diameter of the block
in use and the depth of the groove. The sheave
diameter should be at least eight times the rope
diameter and ideally, the sheave diameter
should be around the order of 18 times the
rope diameter. A smaller sheave forces the wire
rope around a tighter curve, increasing the risk
of damage to the rope
Share this post
Link to post
Eight times the rope diameter doesn’t sound too bad, but I agree that 18 would be a challenge! These figures look to be specifically related to wire rope though which isn’t as issue with a capstan winch.
Share this post
Link to post
Join the conversation
You can post now and register later. If you have an account, sign in now to post with your account.
Note: Your post will require moderator approval before it will be visible.
Guest
Reply to this topic...
×   Pasted as rich text.   Paste as plain text instead
  Only 75 emoji are allowed.
×   Your link has been automatically embedded.   Display as a link instead
×   Your previous content has been restored.   Clear editor
×   You cannot paste images directly. Upload or insert images from URL.
