Jonsey13
Stihl BR700 backpack blower
Purchased earlier this year, used daily for a few hours a day, more in the winter, was a really powerful blower when new, but all of a sudden has lost some power, cleaned fuel tank and changed filters, air filter, but still not much difference, have not done the valve adjustment yet to see if this would make any difference, anyone had similar problems and a fixable solution?
Share this post
Link to post
15 minutes ago, Jonsey13 said:
Green super stihl oil, and run aspen every 4-5 tank
I would suggest using Aspen for every tank or not at all . The pump fuel will have removed the coating on the rubber components  ( that is put there to keep it supple ) but continue to keep them supple as it is slowly dissolving them .  Aspen wont remove the coating if used from the get go but  but won't keep it supple if used intermittently with pump fuel .
Share this post
Link to post
Do you reckon this is the cause for the loss of power?
Share this post
Link to post
No idea bud but ..... pump fuel will over time , and I mean over time dissolve the rubber components . This is sometimes made more apparent when people switch to Aspen after a saw has been run on pump fuel for a long time .
Share this post
Link to post
Ok right oil, biggest cause out! May be unrelated but in the past month we have had to replace in 2 of our blowers the plastic cam that controls the valves. The small metal piece that comes out centrefugally ( if thats even a word) was getting stuck out which was knocking the exhaust valve at the same time as the other valve, causing low compression. Our fitter did it, i just get the reports, so im not sure the ins and outs of it all ( nor am i a fitter) but that solved low power issues
Share this post
Link to post
Have used the stihl super on the recommendations of my local stihl dealer ?, time to find my receipt and see if it’s still in warranty!, if out, if you see your fitter, could you ask if it’s a straight forward job to
fix myself please ??
Share this post
Link to post
Was the 2 blowers you had fixed Br700?
Share this post
Link to post
600’s, back plates off, fan and flywheel off ( its sort of dog bone / peanut shaped not round) , ribbed casing off ( its square) and its the plastic cog in there, £10 to buy. Plus some red gasket sealant, takes him an hour, plus 24 hrs for sealant to dry, OR take it to a workshop if ur not to adventurous
Share this post
Link to post
Join the conversation
You can post now and register later. If you have an account, sign in now to post with your account.
Note: Your post will require moderator approval before it will be visible.
Guest
Reply to this topic...
×   Pasted as rich text.   Paste as plain text instead
  Only 75 emoji are allowed.
×   Your link has been automatically embedded.   Display as a link instead
×   Your previous content has been restored.   Clear editor
×   You cannot paste images directly. Upload or insert images from URL.
  • Tip site reviews
