Carl358
Stihl HS76 engine runs flat
Hi, I have a Stihl HS76 hedge trimmer, it runs and ticks over fine, but when you come to rev it, it’s slow, and only revs slightly higher than tick over but sounds really flat.
I tried to adjust the carb but no luck, new carb kit bought, noticed a chip out of a part of it so brand new carb bought and fitted. Same issue.
Compression i thought, removed spark plug which virtually fell out, so just fitted a new thread to it (helicoil) fitted nicely, new plug too. Same issue after trying to set up the carb but just doesn’t seem to want to have any guts to it. Compression is fine too, I’m nearly at a loss!! Anyone any other ideas???
Share this post
Link to post
20 hours ago, lurkalot said:
Blocked exhaust perhaps.  Check muffler and exhaust port.
Just cleaned out the exhaust muffler and Boom!! Purring like a kitten now! Didn’t even think of that one!! Every day’s a school day! Thanks lurkalot, much appreciated!!
Share this post
Link to post
Join the conversation
You can post now and register later. If you have an account, sign in now to post with your account.
Note: Your post will require moderator approval before it will be visible.
Guest
Reply to this topic...
×   Pasted as rich text.   Paste as plain text instead
  Only 75 emoji are allowed.
×   Your link has been automatically embedded.   Display as a link instead
×   Your previous content has been restored.   Clear editor
×   You cannot paste images directly. Upload or insert images from URL.
