corylus
Storing willow stobs
Because of our recent floods I have to carry out quite a bit of riverbank work.
I have a willowy island to remove but also have a couple of areas of bank to repair that I intend to plant with these ‘harvested’ willow stobs. The initial works (next week or two) will be cutting the willow then removing said island. The bank repairs will be done toward the end of winter and then planted.
How (if it’s indeed possible) should I store the willow stobs for that length of time?
Ta in advance....
Share this post
Link to post
Can’t help with question I’m afraid but interested to know what a stob is.
Share this post
Link to post
Guess it's another word for a set? (Cutting of willow etc. to replant by pushing into the ground).
To try and answer the OP's question, I think you'll struggle to keep em that long. You can store them for a few days somewhere damp and cool or even heel them in in damp sand, but for that length of time they'll probably be rooting and you'll damage the roots when you pull them out again.
Share this post
Link to post
Cut bits of willow tree are so easy to come by that I wouldn't stress yourself trying to store material cut now.  When the time comes to stick cuttings in the ground just ask local tree guys or on here and you'll source what you want with not problem.
If you're determined to use what you have available now put them in the ground to root and harvest cuttings from them in late winter 😊
Edited by nepia
Share this post
Link to post
I always thought it was a scotish word for stake
Share this post
Link to post
stob
/stɒb/
noun
DIALECTSCOTTISH
  1. a broken branch or a stump.
    "old roots and stobs and crackling leaves"
    • a stake used for fencing.
      Round here in Co Antrim I have heard locals refer to fence posts as "paling stabs"
Edited by difflock
additional detail
Share this post
Link to post
Marcus the first time I came across the term it was used for a hot and cold device for creosoting stakes, it was marketed as The Stobster. The broken branch usage seems close to stub.
Share this post
Link to post
To me a stob is a strainer, or sometimes just fenceposts in general
Share this post
Link to post
Cheers peeps for the replies.
I wasn’t hopeful that I could store that long. I can get willow stobs (sorry I shouldn’t have used such a ‘local’ term but I’ve always known short lengths of wood etches that) fairly  easily but these are very close to where I want to replant, lovely and straight, of local provenance and are coming out anyway.
Oh well plan B.....
Share this post
Link to post
Join the conversation
You can post now and register later. If you have an account, sign in now to post with your account.
Note: Your post will require moderator approval before it will be visible.
Guest
Reply to this topic...
×   Pasted as rich text.   Paste as plain text instead
  Only 75 emoji are allowed.
×   Your link has been automatically embedded.   Display as a link instead
×   Your previous content has been restored.   Clear editor
×   You cannot paste images directly. Upload or insert images from URL.
