adam_h_86
Still woodboss 028 won’t run?!
Hello - advice wanted please! I’ve been given a Stihl woodboss to use to cut up firewood etc, it’s sat in a cupboard at our workshop for 20 years?! I’ve changed all the service bits (new carb, fuel line, plug and fuel filter. It seems to start but only run for five seconds then dies and won’t restart?! Is there a something I’ve missed?! A vacuum hose or something that pulls the fuel through?! 😣 any help would be gladly received 👍also can’t work out where this screw goes back?! Any ideas?!
Share this post
Link to post
I would start with a carb  strip n new fuel/ impulse pipe. New plug Obvs.  20 yrs is too long to expect it to fire up at all ! But good find n def worth the effort . K
Share this post
Link to post
He has done that and more ...
Share this post
Link to post
Is the compression OK? It should have between 150-170psi. If you don't have a compression gauge, pick the saw up by the starter/recoil handle and it should drop slowly with distinct holds where the piston comes to top dead centre. A full drop on the handle should take in the region of 8-20 seconds.
If this doesn't grab you, remove the muffler and look at the piston through the exhaust port and see if it looks scored.
Failing this, it may be the impulse line, split manifold, dodgy Chinese carb, etc and the screw looks like part 1121 791 6105 some sort of screw from the top AV buffer.
Share this post
Link to post
Apologies Mr Stubby, I would add crank bearing seals to the list also, if it's suckling air thru perished seals-won't rev out. K
Share this post
Link to post
If you are interested in how the cab works have a look at the attached Walbro info.
Briefly: On choke setting fuel is sucked into carb and the intake port by the piston on its down stroke. During normal running, one half of the carb operates like a pump, lifting fuel from the tank into the other half of the carb - the metering side.
Once you have fuel in the carb (and in the saw) from being on the choke setting, if you then take it off choke and the saw runs for a few seconds (while the fuel is used up), then either the carb settings are way out or the carb isn't pumping fuel from the tank.
Walbro.pdf
Edited by bmp01
Share this post
Link to post
Thanks for all the advice! This is the service kit I bought -
https://rover.ebay.com/rover/0/0/0?mpre=https%3A%2F%2Fwww.ebay.co.uk%2Fulk%2Fitm%2F332944691969
is that a Chinese  carb?! Are they a load of rubbish, haven’t done anything to the new carb just bolted it in and would the two screws out a turn and a quarter, I look Further into it!
Share this post
Link to post
Have a go at tuning that carb. Turn and a quarter on each should get it to run, check the idle screw as this could need some turns in
Share this post
Link to post
Join the conversation
You can post now and register later. If you have an account, sign in now to post with your account.
Note: Your post will require moderator approval before it will be visible.
Guest
Reply to this topic...
×   Pasted as rich text.   Paste as plain text instead
  Only 75 emoji are allowed.
×   Your link has been automatically embedded.   Display as a link instead
×   Your previous content has been restored.   Clear editor
×   You cannot paste images directly. Upload or insert images from URL.
