Swampster
HT131 Drive Tube Assembly
Can anyone confirm if the splined drive shaft that runs up the centre of the tube consists of one or two parts? Drive to the saw head has stopped and I cannot work out what the failure is, the extended tube will not fully house either. Any help or experience appreciated.
Adam
Edited by Swampster
Spelling
Share this post
Link to post
there are 2 shafts. One an externally splined shaft and the other an internally splined tube and they slide inside each other ooh er. There is sometimes a sacrificial plastic drive extension at the saw head of the shaft and this is there to snap if you overload it. Does the top of the shaft turn with the engine running?.
You've not been using it with a hedgecutter head have you?
Share this post
Link to post
Ok, what happens if you do ? Been thinking i might give that a go, or not if it wrecks the tube 😕
Share this post
Link to post
Has a tendency to overload the shaft if you jam the hedgecutter head cutting too thick a bit, i use mine with a hedgecutter head.
The pole sawhead has a degree of slippage as the drive sprocket is not fixed to the shaft directly it is driven by belvill ie frictione washers
Share this post
Link to post
The externally splined shaft is in two sections, the shorter part (power unit end) has a sprung ring around it, presumably to keep it in position? My question is; should there be two sections or has my one snapped?
Share this post
Link to post
Main Inner and outer are of fairly equal length as one slides inside the other, The short piece of outer nearest the engine I believe pushes over a snap ring on the inner to keep it in place.  The long piece of outer has a circlip at engine end.  Sorry I have to hold my hands up and admit, I've repaired a few of the older telescopic poles, but not one a 131. Just going by the diagram.
I must say, Stihl win the award again for over complicating such a simple thing.  They should really see how Echo make theirs, so simple and easy to repair.  I changed a inner tube and drive shaft on one of the Echo's in about fifteen minutes.
Share this post
Link to post
37 minutes ago, Swampster said:
Thanks Lurkalot, I'm still not clear so will get a picture later, 1000 words and all that.
I'm following this as I stripped one down as the shaft was bent, tried to straighten it and never did get it back together again.
Share this post
Link to post
Join the conversation
You can post now and register later. If you have an account, sign in now to post with your account.
Note: Your post will require moderator approval before it will be visible.
Guest
Reply to this topic...
×   Pasted as rich text.   Paste as plain text instead
  Only 75 emoji are allowed.
×   Your link has been automatically embedded.   Display as a link instead
×   Your previous content has been restored.   Clear editor
×   You cannot paste images directly. Upload or insert images from URL.
