Fred B timber
Wanted AEC matador spares
6 hours ago, Fred B timber said:
Morning all I'm looking for any old AEC matador spares that you might want to sell, good prices paid. Please let me know what you've got
07779003635
Are you based near Sudbury, Suffolk?
Share this post
Link to post
Anything specific in mind ?,  I had 39 years as a specialist HGV parts wholesaler in a past life.   Most of the air brake gear you should be able to get rebuilt,  brake linings were tricky even 30 years ago as the holes were randomly drilled.   Best way is to have a specialist drill and countersink and then rivet them on. Took me almost a week to do a set of 12 shoes.  Filters should be no problem,  Coopers/Fram should still do them.
A
Share this post
Link to post
I thought it was the asbestos based ones that were drilled and riveted, the modern (lower friction) ones being bonded??
I say this from when I had the clutch and brake bands on the winch done, the clutch never pulled as much with the modern material.
Share this post
Link to post
You can still get modern ones riveted. Ive had motorbike ones done.
H
Share this post
Link to post
The set I did was early 1970s,  the linings fom memory had a fair taper so going the bonded route was not really an option,  been out of that industry for 10 years now,  so just dont know what the current state of play would be.    Dependng on roughly where you are I might be able to recommend someone if needed,
A
Share this post
Link to post
A
I was referring to when I relined the Igland winches not a Matador and I doubt I shall do it again but thanks.
RE Matador spares I asked the chap I help out with and it seems he only has a set of fairleads left.
Share this post
Link to post
2 hours ago, Fred B timber said:
Hi openspaceman I'd be very interested in the rollers as I missing them on one of my matadors
I passed your number on to him, remind me after 6 June memorial events if you don't hear from him.
Share this post
Link to post
Ah,  ok,  limited experience on brake bands on winches,  only on large excavators.   Brake bands are usually bonded and riveted.
A
Share this post
Link to post
Join the conversation
You can post now and register later. If you have an account, sign in now to post with your account.
Note: Your post will require moderator approval before it will be visible.
Guest
Reply to this topic...
×   Pasted as rich text.   Paste as plain text instead
  Only 75 emoji are allowed.
×   Your link has been automatically embedded.   Display as a link instead
×   Your previous content has been restored.   Clear editor
×   You cannot paste images directly. Upload or insert images from URL.
