Sign in to follow this
harvey b davison
Battery saw
Hi, does anyone carve with either an electric saw or battery saw.
I'm wanting to do more carving, but to do so I will have to do it in my garage, so a petrol saw is a definite no no.
I have a cheap Bosch saw which I have just bought, but I'm thinking about getting a battery saw. Will a battery saw stand up to the continuous stop start of carving.
Any info much appreciated
Cheers
H.
Share this post
Link to post
Cheers
H.
Never used a battery saw for carving. Suppose they might be alright, but you have alot of trigger time so expect you will chin the batteries pretty fast ( depending how big things you make are.) I know a day carving usually uses alot more fuel than a normal day climbing/felling.
What ever you consider check that the trigger isn't just on/off. Pretty poor trying to carve with electric saws like this. I have had a husqvarna 321e and a stihl mse 220 for carving. Dont really get with either but the stihl is better. But numb and cumbersome, but doable if your confined to a garage!
Share this post
Link to post
If not battery, what corded saws would you folks suggest? I was looking at the battery ones, and what they ask for the saw at the start and then the batteries afterwards, has turned me off of them rather quickly. I want to get in to doing more carving up in Wicklow in my back garden instead of having to go all the way back to the estate in Waterford I'm a forester of. Mebbe @shavey has the Makita versions in stock?
Edited by wyk
Share this post
Link to post
Hi Wyk
Shavey is sending me one of his 18v dolmar saws to try with a carving bar on. So I'm looking forward to trying it out. Also I have a cheap Bosch electric saw, I've not tried it with carving but it's on my list of things to do. I got the Bosch as it was on special offer for about £50 when I saw it.
H.
Share this post
Link to post
Had a go with stihl msa 120 today. Great little saw but trigger is on/off no where inbetween. This may well effect carving
Anyone know if this is the same on the 160t? Or ms200 @roughhewn?
Share this post
Link to post
Trigger is variable on msa160c & the msa200c,  they really are the best for detail work not so much for general carving with 1/4" carving chain and bar, real slow chain speed and very grabby,  but great with the r7 carving bar and tiny 0.43?micro pico chain
Share this post
Link to post
Join the conversation
You can post now and register later. If you have an account, sign in now to post with your account.
Note: Your post will require moderator approval before it will be visible.
Guest
Reply to this topic...
×   Pasted as rich text.   Paste as plain text instead
  Only 75 emoji are allowed.
×   Your link has been automatically embedded.   Display as a link instead
×   Your previous content has been restored.   Clear editor
×   You cannot paste images directly. Upload or insert images from URL.
