Sign in to follow this
bettybobbymeggie
Rattly husky 61
Evening all,
This is my first post on this forum. I have an old Husky 61 (c.1987) that starts and runs but it is noisy - the usual clatter you get on tickover from the clutch with the brake off is normal for this saw but with the brake on it tick's over quietly. The noise I don't like comes at full throttle and sounds rough.
I have removed the cylinder and piston which was lightly scored and will be replaced. I am doubtful this is the source of the noise which I think is lower down. The crank itself has no play at all and the needle bearing feels good. The only thing I noticed is if I turn it over by hand (piston off so just moving the crank shaft with my fingers on the piston rod - clutch and flywheel still in place) I can hear the ball bearings clicking into place - are these not quite tightly packed?
I have a second 61 (c.1986) which runs sweet and is actually the saw I did my Lantra training with. I was wondering if it would be an idea if I swapped the top end and piston to see if that eliminated the noise?
Apologies for the stupid questions, any suggestions would be welcome!
Thanks,
Jake.
Share this post
Link to post
Why would you strip a perfectly good saw to try to fix an old clunker ? If you can hear the bearings then something is wrong with the bearings, swapping the piston and cylinder will not do anything to alleviate that problem.
Share this post
Link to post
sounds like a bearing cage has collapsed - surprising it didn't take out the cylinder. Simplest way of finding out is to pull the seals and look but you will only see anything if the seal is a large one. The flywheel side one is mounted in a mounting plate, I think the other one may be in the oil pump!
Better than stripping the bottom end.
Share this post
Link to post
Just send it to Spud then you will have 2 perfectly good working saws . Simples .
Share this post
Link to post
I was just going to do it to diagnose the problem but it sounds like the bearings are shot so I will skip that.
Good tips, thanks. I'll have a look tomorrow.
44 minutes ago, woody paul said:
Is it with chain moving or stationery.
Moving.
Thanks for the help!
Share this post
Link to post
Spud is quite correct the drive side seal is in the pump housing, turning the crank with the flywheel connected you will feel a lumpiness as it passes the ignition unit, could this be what you are feeling? the bearings are just 6205s and woul.d require splitting the cases.
Share this post
Link to post
Why I asked if when chain moving was had a chatty noise on my 61 turned out to be bar plate ( thin plate which goes between bar and crankcase at bar mount) had got bent and was rubbing on chain rivets as chain went round.
Share this post
Link to post
