Ms 390 not oiling
islander
if it works without the bar on then doesn't with the bar fitted, it would generally be the oil hole in the bar that is blocked - worth checking again. If it is clear and it still doesn't oil then it sounds like either the pump is plugged, the pickup is blocked, the worm is stripped or the pump has worn.
It is usually a case of stripping all the bits out, inspecting them and replacing whatever isn't right.
