Sign in to follow this
Harvey2018
Flail hire for excavator
Hi All,
I'm in need of a flail to hire for a couple of weeks to put on a 6t excavator.  Does anyone know of a firm in Kent that does them? Its for clearing a lot of willow re-gen and brambles. Willow re-gen in upto 3-4 inch diameter, Has to be excavator mounted as the bank is to steep for the a bobcat style machine
Your help would be very much appreciated as I need to get the cost in ASAP
Cheers guys
Share this post
Link to post
Approved hydraulics do, not sure how delivery/collection would work though without paying pallets both ways
Share this post
Link to post
Hmm.. Good luck with that...
I'd be very surprised if the flow-rate on a 6 ton machine was sufficient to enable the flailing of anything over 2" diameter woody material -but happy to be told otherwise !
-Think you'd need something more like a 13 tonner to do that ?
What about using a tractor and long reach hedge cutter for the bulk of the work (easier availability), and then hand-cutting and chipping the remaining 2" and-over willow stems  ?
Share this post
Link to post
The flail on my 6 tonne machine manages about 4-5 inch diameter
that’s using a femac te80 rev forestal flail
Share this post
Link to post
On 15/01/2019 at 15:09, Harvey2018 said:
Hi All,
Cheers guys
I guess you got this sorted by now. If not, i don't know if this head is available without the excavator or not but it might be worth a call
6ton forestry excavator hire
Share this post
Link to post
All sorted and done now mate, took along time to flail a whole field lol
Unfortunately couldnt get any tractors up into the area. 5 acres is alot to do 900mm at a time
Share this post
Link to post
