Does anyone has experience with a homemade bigshot? Or similar throwline-shooting-devices using rubber? I also would like to know the diameter of the rod on the head of the bigshot, thanks!
Share this post
Link to post
No personal experience but know of a lad who set one up on a wooden pole instead of the official version - it snapped and smashed his face/eye socket really badly.... Be careful!
Share this post
Link to post
i made my own , picture on page 3.
The rubber part (Big Shot) is 34 pounds or 84 for the complete head .
for anything over 20 meters the big shot is definitely worth having
just buy the complete head it slides on most poles
Share this post
Link to post
Thing is if that rubber comes off under force on some Heath Robinson contraption it has the potential to really ruin your day or as above the pole shatters ... personally I’d buy ready made ... not that I’m calling Darrins badly made or out but for the money it’s not worth skimping on.
Share this post
Link to post
Definitely worth taking note about the poles. The recommended (only type that should be used) are reinforced fibreglass, the standard fibreglass poles can shatter easily causing major injuries.
Share this post
Link to post
I did have one of the Jameson’s poles flex and brake on me ... fixed it with broomstick up the middle... not ideal.
Share this post
Link to post
I bought the Tekeuchi or whatevery its called, the Japanese version, head only, and made my own pole out of a section of old fiberglass windsurfer mast, wide end mating with the catapult head and some sleeves of pvc pipe. A hole, drilled through both the shaft and sleeves, then a steel peg aligns them and keeps everything together nicely. Use an archery trigger but don't bother with a ratcheting tensioner system. Windsurfer mast is the way to go, you will never, ever break one of those.
Share this post
Link to post
Considering the price of the tried and tested models, and the risk of serious injury of a home made one, why would you make your own? (genuine question!)
Share this post
Link to post
Join the conversation
You can post now and register later. If you have an account, sign in now to post with your account.
Note: Your post will require moderator approval before it will be visible.
Guest
Reply to this topic...
×   Pasted as rich text.   Paste as plain text instead
  Only 75 emoji are allowed.
×   Your link has been automatically embedded.   Display as a link instead
×   Your previous content has been restored.   Clear editor
×   You cannot paste images directly. Upload or insert images from URL.
