Sign in to follow this
hinser13
Timberwolf 150 black smoke chipping
When chipping black smoke coming out of exhaust! !! Ordered a service pack and changed all 3 filters which improved black smoke issue !
Now though still get black smoke under stress when chipping bigger bits !!
any help is appreciated ..
Share this post
Link to post
Crankcase breather needs a wipe through too I would think.
Share this post
Link to post
How old is the machine / engine?  V1305 or V1505 Kubota? We had an old Entec in last year that was part exchanged with exactly the same symptoms.  New rings and bore hone was needed.
See if you can determine whether it is over fuelling or breathing / chuffing oil.
Wouldn't hurt to do a compression test whatever your issue is. Even if its to know you have a good base engine.
Might find that someone has previously given the fuelling a tweak. Or has this started in your ownership?
Share this post
Link to post
I see you say 3 filters fitted . There are 4 filters , Oil, in-line fuel , screw-on fuel and an air filter. Black smoke is usually an air clean problem . did you do the air filter ? also check the mushroom on the top , if that clogs it can cause black smoke.  Gareth of Green Plant.
Share this post
Link to post
Yes  but it was not unknown for people to break the lead seal and open up the rack in days of yore.
Valmet's forwarders did this a lot as standard if you booted them, I did an assessment on one of FC Ae's forwarders and got marked down by Mr. Coombie for saying it was a machine fault.
Share this post
Link to post
Join the conversation
You can post now and register later. If you have an account, sign in now to post with your account.
Note: Your post will require moderator approval before it will be visible.
Guest
Reply to this topic...
×   Pasted as rich text.   Paste as plain text instead
  Only 75 emoji are allowed.
×   Your link has been automatically embedded.   Display as a link instead
×   Your previous content has been restored.   Clear editor
×   You cannot paste images directly. Upload or insert images from URL.
