greenhouse for drying
westphalian
I think you will have to cut some of the neglected foliage back away from the outside then dig the brambles out from the inside replace the missing glass ( you will not get a fork lift through the door) stack it in crates so it will not fall over and bust the glass maybe a auto roof vent will help  and it will dry them
If you can't get a forklift in a walking floor design could work. Maybe add a chp boiler to heat it and power the fan at the same time...
Seriously though, if you cut back the brash and fixed the glass I think it would dry nicely in there. A small solar fan would probably reduce the risk of mold but it's a balancing act between airflow and keeping the heat in.
