beardedone
Need help with Nissan cabstar 2006 engine
So I need to find the glow plugs on my engine and I feel like a right idiot because I can't find them at all and nor can the mechanic I asked to look (which made me feel better) .
If someone's got a picture of the engine and where they are on it please let me post it as Im at a loose end here.
Cheers
B
Share this post
Link to post
Cheers
B
Are you sure it has any? I thought they were 2.5 common rail after 2002 so wouldn't necessarily have glow plugs
Share this post
Link to post
I've got an engine light on that says glow plugs/glow plug relay so I'm thinking there has to be. It's starting funny too so it has all the signs but I can't find the blasted things
Share this post
Link to post
Often they are below injectors if you can find them
Share this post
Link to post
i take it its the 3 ltr older one or is the the new 2.5ltr ? start with the fuses,
Share this post
Link to post
3ltr old one. Cheers for all the replies
Share this post
Link to post
its definatly got heater plugs or plug it may be just one in the inlet manifold i will have a look at mine in the morning and see what i come up with,
Share this post
Link to post
hi had a look this morning it looks like it has one heater plug in the in let manifold that is situated on top of the engine if you look under the engine cover its a square moulding in the inlet manifold with 2 elec items the top one looks as if it could be a heater plug , but not 100% on that good luck and have some plasters ready as they are so awkward to work on ,but at least theres one thing you dont have to do it very often.
Share this post
Link to post
Checked on a spares website and that indicates the  2004 3 ltr model has four glow plugs
try checking one of these sites and using your reg number it would at least tell you if you have one per pot or one in the Manifold ( I would have thought this was an outdated preheat method.
Regards,
NoPedigree
Edited by Nopedigree
Share this post
Link to post
Regards,
NoPedigree
mine is 2004 and i cant find 4 glow plugs can find 1 in the inlet manifold tho,
Share this post
Link to post
