Sign in to follow this
Chessa
Mouldy birch
Mouldy birch for personal use: can I burn it? (Once it’s dried out in the hotly ancipated warmth of summer).
Edited by Chessa
Share this post
Link to post
Burns ok, just not as much heat or long lasting. Birch rapidly decays if stored uncovered
Share this post
Link to post
Yes burn it, but get it in a log shed as soon as you can, it will be compost in a couple of years!
Share this post
Link to post
Thank you to both above. It is as I feared, but there is at least some hope!
Edited by Chessa
Share this post
Link to post
Split and get the bark off . The bark retains the moisture  Under cover , off the ground , with plenty of air flow . It will be fine .
Edited by Stubby
Share this post
Link to post
The bark burns better than the wood I find and it tends to take itself off after the wood has been split. The thicker bark makes good kindling.
Share this post
Link to post
If you scratch up the inside of the more papery bark with a sharp knife, the shavings will catch from a spark off a flint and steel.
Share this post
Link to post
Join the conversation
You can post now and register later. If you have an account, sign in now to post with your account.
Note: Your post will require moderator approval before it will be visible.
Guest
Reply to this topic...
×   Pasted as rich text.   Paste as plain text instead
  Only 75 emoji are allowed.
×   Your link has been automatically embedded.   Display as a link instead
×   Your previous content has been restored.   Clear editor
×   You cannot paste images directly. Upload or insert images from URL.
