flatyre
Cooing fan not switching off?
Hey folks started up the tipper today and the cooling fan came on straight away, ran the engine for about fifteen seconds then switched it off, but the cooling fan kept running, had to disconnect the battery to knock it off, it didn't come back on once I re connected the battery. don't think its a thermostat issue, what else could it be?
thanks.
Share this post
Link to post
Was it half way through a DPF regen and never finished - had a similar problem on a diesel Focus as the DPF wasn't getting cleaned up enough - ended up having it bypassed and a remap, all's good now.
Share this post
Link to post
Relays are clever things.
But, breaking a circuit is much more wearing than making one. The contacts get welded together by the current, everytime the relay needs to open or close it makes a spark. When closing the circuit this spark gets smaller as the contacts are moving together, but when opening a circuit there is a current flow to interrupt making not only a bigger spark but the very act of the contacts moving away from each other sort of stretches the spark. if it gets stuck in the closed position the contacts will have welded together by that spark.
In short: Just stick a new one in, they cost pennies
Share this post
Link to post
That's why many relays have a snubber diode across the coil, if it doesn't maybe worth fitting one they only cost pennies.
Share this post
Link to post
Join the conversation
You can post now and register later. If you have an account, sign in now to post with your account.
Note: Your post will require moderator approval before it will be visible.
Guest
Reply to this topic...
×   Pasted as rich text.   Paste as plain text instead
  Only 75 emoji are allowed.
×   Your link has been automatically embedded.   Display as a link instead
×   Your previous content has been restored.   Clear editor
×   You cannot paste images directly. Upload or insert images from URL.
