Sign in to follow this
Little Butch
Saw benches
Are they worth it over a chainsaw when running a small scale firewood business? I've never used one but they look much easier and faster for cutting cord up than by chainsaw?
What size range of cord do they generally cut? I don't have a tractor so would have to be a standalone unit.
Photos of of your saws welcome :D
Share this post
Link to post
I have a similar version to this https://www.ebay.co.uk/itm/700-MM-PETROL-CIRCULAR-LOG-SAW-4-STROKE-9KW-12-2-HP-SCHEPPACH-HS700GE/162866022549?epid=3013243538&hash=item25eb924895:g:SG8AAOSw1GlaZw3T
They cut 10" diam logs, or cut and rotate larger ones. They are far quicker and a lot less strenuous to use than a chainsaw.
Share this post
Link to post
Mine was £550 from Germany. Run of the mill made in China with a 13hp honda clone engine. Starts first time and have only had to replace the drive belts with better quality ones. It has cut a lot of timber and has paid for itself cutting other peoples log piles.
Share this post
Link to post
Got a Balfor saw bench, you can cut up to 12" diameter logs on it although I tend to ring up anything over 10" with a chainsaw now as they can be a fair weight to lift on to the saw bench. Had it for about 3 years. A lot better than using a chainsaw. Always say this every time the subject comes up on here but wish I could afford to buy the version with the conveyor on it!
Share this post
Link to post
I've got the Balfour saw bench. It's brilliant, don't bother with a chainsaw unless the bits are too big. Wish I'd gone for the conveyer as well!
Share this post
Link to post
59 minutes ago, Little Butch said:
They sound a winner then! I'll look at the Balfour but I bet they're a fair step up in price?
They're 2 or 3 times the price of the chinese saw benches. But going by the ebay link above, chinese one weighs 120kg, balfor weighs 200kg! Which is quite a difference
Share this post
Link to post
The Chinese ones don't compare to the likes of Balfour, but it's horses for courses. I'm on a very limited budget and log on a small scale, so the price and item quality suited me fine. They are such a simple machine and easily worked on. Replace the belts with quality items, change the engine oil regularly and there is no reason it won't keep going. I have just moved onto a small petrol processor to make life even easier, I don't do any more logs, just getting older.
Share this post
Link to post
