Bloom
Bluetooth helmet kit
I'm now sick of the Sena wiring! 2nd set to fail this year and yes, we do look after them. Also I've had to glue one of the batteries onto the base plate as it no longer stays in the clip.
I'm not slagging off the Sena product but now just want something more robust.
I want something as good as the Peltor but for £3.99. All good suggestions appreciated.
What model are you using?
Share this post
Link to post
Not had any wiring issues for over a year now with Sena. A small zip tie will hold the battery on.
We have also removed the cover from the dial part. Doesn't get banged on branches now.
Share this post
Link to post
Where do you put the zip tie? I can’t see a way of fitting it but I have a different model to yours.
Share this post
Link to post
I'll put a photo on later.
Share this post
Link to post
On 25/08/2018 at 14:16, Ty Korrigan said:
Has any-one stretched to the protos specific bluetooth?
If so, what are your thoughts?
 I'm just not up to shouting anymore.
   Stuart
The new Protos 4 user system (BT-COM) will be launching in the UK at the APF in a few weeks time.  If you are visiting, you would be very welcome on our stand (G16) to try them out.
Share this post
Link to post
Will it be compatible with other Bluetooth devices? i.e.: Sena
Share this post
Link to post
The Protos BT-COM complies with Bluetooth specification 4.2 and supports a range of compatible profiles.  So in theory I don't see why it would not be able to link with another system.
Currently the only certified communication systems for use with Protos Integral are the Protos Bluetooth System (BT-COM) and 5 options from 3M Peltor.
Share this post
Link to post
Sena comms sets are Bluetooth 4.1 so I’m guessing that they won’t be compatible with these new Protos 4.2.
Share this post
Link to post
Join the conversation
You can post now and register later. If you have an account, sign in now to post with your account.
Note: Your post will require moderator approval before it will be visible.
Guest
Reply to this topic...
×   Pasted as rich text.   Paste as plain text instead
  Only 75 emoji are allowed.
×   Your link has been automatically embedded.   Display as a link instead
×   Your previous content has been restored.   Clear editor
×   You cannot paste images directly. Upload or insert images from URL.
