Sign in to follow this
RMB68
HUSKY 580BTS OR STIHL BR700 MAGNUM
Evening all,
Pondering about which one of these blowers to buy.Havent had great success with 4 mix engines but know nothing of the Husky model.Any nuggets of wisdom greatly appreciated.
RMB
Share this post
Link to post
580 is a standard 2 stroke engine and  far more reliable. The trigger is mounted on the side of the pipe so when you give it full throttle your hand doesn’t lift like it does on the stihl which is mounted directly on top of the tube. The 580 may still be the most powerful on the market it was at one point would need to check the spec. I have one it’s excellent. You can clear a big area very quickly
Edited by Sveriges
Share this post
Link to post
Join the conversation
You can post now and register later. If you have an account, sign in now to post with your account.
Note: Your post will require moderator approval before it will be visible.
Guest
Reply to this topic...
×   Pasted as rich text.   Paste as plain text instead
  Only 75 emoji are allowed.
×   Your link has been automatically embedded.   Display as a link instead
×   Your previous content has been restored.   Clear editor
×   You cannot paste images directly. Upload or insert images from URL.
