saving fuel
simonm
We are starting a new grounds maintenance contract that covers a large area, i am trying to figure out ways of saving fuel as i think this is going to be 1 of the biggest expenditures. Other than reducing weight on the vehicle & planing journeys well i cant see as there's  going to be much difference! ride on runs on red which is nice & cheap but both walk behind mowers are petrol & the van does around 21mpg...ideas?
Do as much as you can with ride on mower. Get Honda engine mowers as they have been the most efficient walk behinds I’ve used.
If you’ve got a large geographical area then aside from changing van there’s not much to be done on that side apart from only taking what you need, but that doesn’t make much difference.
21mpg is horribly bad though even my pickup will do 27 towing mower
Probably not a lot you can do if you are sticking with the same vehicles. Keep on top of servicing and make sure your tyres are at the right pressures is all that occurs to me. Avoud sharp acceleration and braking. Probably only a nominal difference though.
Have you got a fuel card? Perhaps worth shopping around and seeing if you can get a better rate.
We only run 3 vehicles but they all tow. Our diesel bill is £5k ish per year. Painful.
