TreeAbility
Ident help required on larch
Found this on Larch.  It's recent as the tree was inspected a few weeks ago.  Tree leans and its on the holding root side, doh!  Any thoughts please?  I was wondering if Griffola frondosa but possibly not frondy enough?
Share this post
Link to post
As soon as I see a fruiting body on conifer I think Phaeolus schweinitzii - the Dyer's Mazegill - though that one may be a bit lower on the tree than you might expect; typically they're found a few feet up and higher but not exclusively.  Could there be others higher in the tree?
Take a look in the Fungi Directory; a possibility?
Share this post
Link to post
This is a misleading comment (not having a dig) This is indeed Phaeolus but it is not limited to upper/basal areas, in fact quite the opposite, often fruiting from ground in its typical form, from sub surface roots. P schwienitzii is a heart rot fungus limited only to zones of the tree where heartwood exists and transfered (in low resistant species i.e Larix decidua) by root contact. It can be found from the sub surface roots to the upper scaffolds.
Share this post
Link to post
Join the conversation
You can post now and register later. If you have an account, sign in now to post with your account.
Note: Your post will require moderator approval before it will be visible.
Guest
Reply to this topic...
×   Pasted as rich text.   Paste as plain text instead
  Only 75 emoji are allowed.
×   Your link has been automatically embedded.   Display as a link instead
×   Your previous content has been restored.   Clear editor
×   You cannot paste images directly. Upload or insert images from URL.
