Sign in to follow this
mattyboy
L200 tipper uprated suspension?
I have a regular cab L200 with tipping chip box, when i have around 2-3 cube of chip in the back i feel a little floaty driving at speeds above around 40mph. I have 5+1 leaf springs on the rear but standard suspension bits all around i think, what can anyone recommend to aid the drive of this truck with weight in the back, it doesnt feel great! maybe get some even more heavy duty rear springs and heavy duty shocks on the rear?
Share this post
Link to post
Any diff between a level load or heaped up at the headboard, could be too much overhang/ weight behind the axle
Share this post
Link to post
i generally always have it heaped up behind the headboard and gently sloping towards the rear as i thought this would be the best way to carry the load. Would it be better to even it out more to have a flat top to the load of chip you think? Can try this
Share this post
Link to post
I recently updated mine to heavy duty 6+1 on my l200. The backside is up in the air unloaded but once it's rammed and has a 1 ton chipper on the back it sits nicely. Before it felt like you were on a boat
Share this post
Link to post
Any truck loaded is gonna handle like a boat.. have heavy duty rear springs on our 200 tipper and it's a hard ride empty and would probably benifit from new shocks springs and bushes up front as it wollows loaded but reluctant to spend money on her purely because it's not used loaded much.
Share this post
Link to post
Join the conversation
You can post now and register later. If you have an account, sign in now to post with your account.
Note: Your post will require moderator approval before it will be visible.
Guest
Reply to this topic...
×   Pasted as rich text.   Paste as plain text instead
  Only 75 emoji are allowed.
×   Your link has been automatically embedded.   Display as a link instead
×   Your previous content has been restored.   Clear editor
×   You cannot paste images directly. Upload or insert images from URL.
