stihlmadasever
Core strength and climbing
I hit just over 2 minutes earlier but i was trembling like a fat kid in a cake shop.Some of you guys over 3 minutes is tremendous-clearly i have some work to do.
try the"bring Sally up" challenge. If you're a masochist.
Sent from my SM-G930F using Arbtalk mobile app
Share this post
Link to post
G day all,
Im a bit of a gym nut,i like too keep myself fit and strong and i know some of you are the same.
Ive been going to the gym longer than ive been climbing but once i started climbing i noticed a steady increase in my weights on compound exercises such as squats,deadlifts, rows and presses.
Speaking to one of the gym instructors about this he said it was to do with an improvement in core strength which would be a bi product of the tree climbing.
He said a good test is too do a plank and hold that position for as long as possible.The plank is lying in a press up position but with your elbows and forearms on the ground rather than your hands.You should also be on your tip toes and hold that position for as long as you can.
It sounds really easy but its very humbling exercise if your lower back/abdominal walls are weak.
If you can hold for a 90 seconds thats extremelly good
Between 1minute to 90 seconds is good
45secs to a minute is average
Under 45 and you need to improve.
Dont under estimate the results of this simple test,it can highlight a weak lower back,weak abdominals and obliques.Id be interested to see how the climbers fair on this one,we should have a better time than others due to the physical pressure exerted on our core during climbing.
Im just getting near the really good at 1 minute 22.
Anyone want to have a go and post there results?
Oh and you cant do this if your beer belly touches the ground while in the plank position -sorry bollam.:001_tt2:
My Missus was timing me planking there , she got fed up at 3 minutes ish and went to make a cuppa !! I keep telling her I'm an athlete :001_smile::001_smile:
Share this post
Link to post
Shaking by one minute, went till two. I reckon I could do 2:30-3 on a good day. Not bad as I stopped climbing 5 years ago and do nothing physical except a bit of gardening etc...
Share this post
Link to post
I can't do push ups because my left elbow is crook, can I have a note for the teacher.
Share this post
Link to post
Spider-Man press ups are quite masochistic too....
Timon.
Share this post
Link to post
I did two mins relatively easily and that was after 30 sit ups.....not too bad for a 52 year old fart:thumbup:
Share this post
Link to post
52 year old fart...
Thats quite a feat holdin it it for that long...
Bet that was a bit wiffy..
:001_tt2:
Share this post
Link to post
Join the conversation
You can post now and register later. If you have an account, sign in now to post with your account.
Note: Your post will require moderator approval before it will be visible.
Guest
Reply to this topic...
×   Pasted as rich text.   Paste as plain text instead
  Only 75 emoji are allowed.
×   Your link has been automatically embedded.   Display as a link instead
×   Your previous content has been restored.   Clear editor
×   You cannot paste images directly. Upload or insert images from URL.
