Sign in to follow this
Capstankid!
Sweet Chesnut die back.
A client I work for has a huge ( at least 3m across) Sweet chestnut in there property and it's fairly close to the house, the problem is there is a lot of dead in the top but the bottom seems pretty sound. There is that much dead in The top that there wouldn't be much of The tree left. The question is should I just take the dead out and leave the rest or should the full tree be removed.
Sent from my SM-G930F using Arbtalk mobile app
Share this post
Link to post
Adopting the BS3998 'risk assessment' approach to deadwood removal, recognizing it is a niche habitat and therefore important, generally speaking, does it need to be removed or is it a perception of danger rather than actual. If so, can it be reduced in size / length, as opposed to removed all together, to lessen the likelihood of falling and the impact if it does / did.
I would only remove if absolutely necessary and as a last resort.
Playing "devil's advocate" a little bit here...and reminding us what the BS recommends in terms of a risk management approach.
Cheers,
Paul
Share this post
Link to post
Cheers,
Paul
Thanks for the reply Paul,
I would rather see the tree standing but it would be a lot like looking a one sided tree and a pollard would be a waste of timber in my eyes as there doesn't seem to be a lot of growth on the stem.
It needs something done with it as there is a lot of exspensive cars parked under it.
Share this post
Link to post
Can't they park somewhere else...under a 'safer' tree :001_rolleyes:
Cheers,
Paul
Share this post
Link to post
Join the conversation
You can post now and register later. If you have an account, sign in now to post with your account.
Note: Your post will require moderator approval before it will be visible.
Guest
Reply to this topic...
×   Pasted as rich text.   Paste as plain text instead
  Only 75 emoji are allowed.
×   Your link has been automatically embedded.   Display as a link instead
×   Your previous content has been restored.   Clear editor
×   You cannot paste images directly. Upload or insert images from URL.
