Joseph Howard
How do you splice tenex onto a pinto
Hi all,
I want to make a pulley saver but I'm struggling to find any info on the splice necessary to fix a pinto onto an eye to eye.
I believe the first is a locked Brummel. What's the deal with the second one?
Cheers
Share this post
Link to post
Hi Joseph, may I ask, if it's imperative that you have an E2E? Or can an Eye to Whoopie do the same thing for you? There is a trick to E2E's that the length between your eyes has to be passed through the Tenex first, you'll need a piece of wire and a wire fid to accomplish what you want. But, a Whoopie is a great deal easier to make. Also, it will be adjustable. Whereas, an E2E is fixed permanently. Let us know what is more important, if you would?
Share this post
Link to post
Hi Dave,
It really doesn't matter to me how I fix the pulley on as long as it remains retrievable. The eye to whoopie sounds interesting. I've not seen one of those before. Is that what you use?
Cheers
Share this post
Link to post
This is a setup that I made for a RignWrench last year it's not hard to make you just have to be sure to get everything straight and 3 brummells so it doesn't come apart on itself.
Share this post
Link to post
Did you mean that you can splice a brummel eye on each of the cheeks of the Pinto? If so, please go on....
Share this post
Link to post
Yes! You can it's a real bear but you can do it! Well, I know that I can do it. This has a loop then the locking Brummell and the Whoopie is assembled afterwards. Yes there is a spacer between the cheeks of the rigging pulley. The Tenex is also doubled for the loop on the pulley. It's extremely strong and indestructible, the way it's set up!
Share this post
Link to post
You have to unravel the length of Tenex that you need on the one side and redo the weaving when you are done with the 1st side. There are a few great splicers on this forum that can and have done just that! I'm just one of over a dozen or so that know how to do a locking Brummell on each cheek plate. You have to be extremely patient and obviously aware of what you are trying to do, for it to work!
Share this post
Link to post
There is another way to do it without undoing the braids.
Please go on!
Share this post
Link to post
I personally prefer Double Braid when going from cheek to cheek plates, I've spliced dozens of them! They are just if not stronger than Tenex! I'd like to see a Brummell from cheek to cheek Tommy_B
Share this post
Link to post
Join the conversation
You can post now and register later. If you have an account, sign in now to post with your account.
Note: Your post will require moderator approval before it will be visible.
Guest
Reply to this topic...
×   Pasted as rich text.   Paste as plain text instead
  Only 75 emoji are allowed.
×   Your link has been automatically embedded.   Display as a link instead
×   Your previous content has been restored.   Clear editor
×   You cannot paste images directly. Upload or insert images from URL.
