roys
686 Chain Sharpening
So I have done a rare thing and read a set of instructions and wished I hadn't. The instructions say first file with a 4.8mm file and then a 4.5mm file and file 10deg of the level and at 25 deg.
I have no probs with the 25 degrees bit but using two different size files and 10 deg of the level sounds a bit different to me, what do you think?
686 Chain Sharpening.pdf
Share this post
Link to post
Stop reading now :thumbup:
Share this post
Link to post
4.8 when chain is new and when it gets to about half left step down to 4.5 . as the top plate edge moves toward the back of the cutter it slopes down so ideally you would need a slightly smaller file to bereally religious about it .
Share this post
Link to post
Several Oregon chains are 25 degree and 10 degree and are made for Dolmar and Husky.
eg Husky H42 = Dolmar 099 = Oregon 73LPX
Share this post
Link to post
Thanks CJ
Problem is, I use a sharpening jig and I don't think it will allow for that 10 degree offset. Don't have it beside me to say for sure.
How important is the 10 degree offset?
Share this post
Link to post
I kinda do 10 degrees down buy hand on Husky and Oregon chains and level on Stihl chains but it dosn't matter a toss really .
Share this post
Link to post
