Woodworks
What options are there for narrow kerf blades on larger saws?
At present just have two saws. A 346XP with a 15" bar and MS460 with stock 25" bar. A lot of my work is ringing up timber thats too big to go through the processor of say 14"-24". Is there a way to put a narrower bar on the 460 and if not whats the biggest saw that can use a narrower chain?
Thanks
Share this post
Link to post
I once bought a Husky 385 from Canada and it had a 30" bar and chain set up that was .050 gauge so you can get them but not sure over here . Best ask Rob D .
Share this post
Link to post
To my knowledge we are one of very few companies looking at putting narrower kerf bars on larger saws.
And also narrow kerf bars for smaller saws.
We have a full range of GB bars (OK you will need a spacer for Husky saws but we have those as well) inc 20", 24",30", 36", 42", 48" that will take 3/8" Lo Pro chain.
But this is mainly for chainsaw milling - as bear in mind there is a compromise in using a narrow kerf bar.
  • Bar is physically thinner and so floppier
  • Chain is lo pro and IMO does not have the same stay sharp qualities as larger chain
  • You will get more chain stretch and it will happen more often
  • Chain does not seem to oil quite as well (This is just an impression I have personally but it may not be the case).
We also have 12" to 18" bars that take 3/8 .043 - even thinner chain than 3/8 .050.
The 30" bar Stubby is talking about would be 3/8 (standard) .050 - in the US instead of having 3/8 .063 for Stihl and 3/8 .058 for Husky they all seem to like 3/8 .050 bars.
:001_smile:
Share this post
Link to post
:001_smile:
Thanks Rob
Had thought in terms of a larger saw but an 18" bar with a narrow chain would probably do 90% of whats needed. What saws would that be suitable for?
Share this post
Link to post
Hmmm thinking more carefully I have a whole roll of .325" chain so maybe best to get the gutsiest saw that would use this maybe with a 20" bar?
Share this post
Link to post
3120xp with a 208RNDD009 bar
Swap the nose sprocket for a .325" pitch
Swap the clutch for a standard drive spline and a 9 by 325" rim.:lol:
Realistically you're only going to find a small mount Husky(K095) bar in 325 pitch and 58 guage.The largest UK husky is the 560xp(the US 562xp is 3/8) However you may be able to get larger dolly to take this bar.
Share this post
Link to post
Was just reading up on the 560xp. Presume they would be more than happy with a 20" bar? It would fill the gap between my other two saws nicely.
Share this post
Link to post
My 560 is on a 325 narrow kerf 16" bar and goes like a demented thing .
It is ported , but even so it's impressive and I reckon a 20" would be fine.
Sent from my SM-G900F using Arbtalk mobile app
Good to hear
Reading up it seems many have had trouble with the 560. Has yours proved reliable?
Share this post
Link to post
Hello Beau , Rob D has the 24" in the k095 mount which fits the 560 and 6100 but if you didn't want to go that big the 20" is a good alternative if needed to fit between the saws you have in your arsenal
Share this post
Link to post
