Metsaman
Cheap Plasma cutter Nova PL50
it looks like that has a drag tip on it, so you can place the tip on the workpiece and drag it, rather than hovering it over the the steel, I guess that'll cut through about 8mm?
Share this post
Link to post
This plasma cutter don't work that way... this need specially that You hovering a nozzle over the steel, I know that much more expensive plasma cutters work if nozzle is on the workpiece but this don't..
Share this post
Link to post
ha ha ha! I did exactly the same thing when I bought mine, and then a few times afterwards, and ill probably do it again in the future lol but a plasma cutter is a proper boys toy lol when you say cheap? how cheap was it? I think mine was just over £400 and I can cut 8mm cleanly and up to 12mm but it needs tidying up lol and I can put the tip on the workpeace and drag.
Share this post
Link to post
That cost about 400 £.. it was much help when I built cabin for My backhoe..
Share this post
Link to post
Join the conversation
You can post now and register later. If you have an account, sign in now to post with your account.
Note: Your post will require moderator approval before it will be visible.
Guest
Reply to this topic...
×   Pasted as rich text.   Paste as plain text instead
  Only 75 emoji are allowed.
×   Your link has been automatically embedded.   Display as a link instead
×   Your previous content has been restored.   Clear editor
×   You cannot paste images directly. Upload or insert images from URL.
