Logged On
Countryfile, 'Bracken' Fuel?
Wonder if you can turn/bale it in the rain? or did they just go through the motions for the cameras. Ingenious idea though, pity you couldn't do the same with knotweed.
Share this post
Link to post
Just heard the other day - they've discovered a chemical in Jap Knotweed roots that could be the next panacea: cardio protective, anti cancer, anti ageing, weight loss etc etc.
https://newdrugapprovals.org/tag/japanese-knotweed-extract/?iframe=true&preview=true/feed/
Share this post
Link to post
Most bracken is on steep ground , very rare to have land running to hundreds of acres that one could use big heavy equipment . Would not knock the end product though , although if one cut annually the crop would get less each year , not sure how they could get enough supply .
Share this post
Link to post
Join the conversation
You can post now and register later. If you have an account, sign in now to post with your account.
Note: Your post will require moderator approval before it will be visible.
Guest
Reply to this topic...
×   Pasted as rich text.   Paste as plain text instead
  Only 75 emoji are allowed.
×   Your link has been automatically embedded.   Display as a link instead
×   Your previous content has been restored.   Clear editor
×   You cannot paste images directly. Upload or insert images from URL.
